Can you first make sure that you have your security proofs up to date by visiting this page here?
Once you've checked that out try the following steps below:
Delete your profile, clear your cache 3 times, restart your console, and then download your profile.Delete Profile Safely:
Go to Settings, and then select System.
Select Storage.
Select All Devices.
Select Gamer Profiles.
Select the gamertag that you want to delete.
Select Delete.
Select Delete Profile Only. Clear System Cache, don't forget to do it 3 times!Go to Settings, and then select System.
Select Storage.
Highlight Hard Drive, and press Y
Select Clear Cache, and press Yes.
Restart Console Download Profile:Push the middle button on your Xbox 360 controller.
Select Download Profile.
Go to your settings and go to storage, and you will see the internal storage and your pics, and music..and so on..you can click on them and it gives you the option to delete and clean up storage space.. Also clean your cache partition....
What email application are you using? Many will delete everything in the trash after 30 days. You can typically manually delete sooner if you wish to clear it out.
Hello Anonymous. It could be that your phone is looking for a device to pair. You can go to touch Apps and touch Under Wireless & Networks; and slide your finger to the left until your Bluetooth is off. You can check this steps trough the link: Using Bluetooth
Hello Anonymous, You can try to go to settings and go to apps and slide your finger until you see all your apps and tap on camera. In your camera tap on clear cache and force stop and reboot the phone. If you receive the same error try to follow the same path but instead of clear cache, tap on disable and then enable it again and reboot the phone.
Hello there, you can try the following:
1. On the Touchscreen press the MENU. 2. Press FAX. 3. Press SETUP RECEIVE. 4. Press the UP OR DOWN ARROW to choose MEMORY RECEIVE. 5. Press FAX STORAGE.
Then if you want to clear fax memory find clear or reset memory if you are not able to see it then turn the fax storage off then restart the printer then check. Then again turn on the fax storage if you want to store fax in memory. Thank you.
