Toshiba 62HM95 62" HDTV Logo
Posted on Jun 08, 2010
The fans on my Toshiba DLP frequently makes a loud humming noise, as if something is vibrating that should not be. I am not sure if it is the bulb fan, or the ballast fan, but the noise continues after I turn the TV off until it cools down. So, I am assuming it is the bulb fan. The noise does not happen all the time. There are times when I turn the TV on and hear the normal sound of the fan instead of the loud buzzing. There will be times when I do not hear the loud fan noise initially but then will it hear it later after the TV has been on a while. And there are times when I hear the loud buzzing sound of the fan right away.and is there an easy solution to this? I would like to replace the fan myself ! Years ago, I repaired TVs.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1382
Points
My tv just came on by itself and now just keeps going back and forth from off to on over and over
1 Related Answer
Anonymous
  • 5 Answers
  • Posted on Jun 17, 2008
SOURCE: Toshiba DLP fan noise (52hmx95)
UUUUggggghhhh I have a 1 year old Toshiba 50" DLP rear projection and it had fan noise. It also had a wierd dark spot on the screen that really wasn't on the screen itself. I was taken to a service center and held captive for 2-3 weeks and returned with a new light engine. I thought great! 3 weeks to a month later and bordering on expiration of warranty it starts to make a low screeching sound like a small motor in need of lubricant. The picture jumps all over and resembles a 256 color PC Monitor. The service center comes and picks it up and holds it captive for another 2.5 weeks and says they cannot duplicate the problem. I had even sent them a quicktime movie of it in action.
They drop it off and an hour goes by and off she goes again. Now the longer I leave it on the worse it gets and shuts itself down and sometimes blinks the "light engine" code. Spoke with Toshiba and they are escalating it and should hear back in 3 days... OMG. Kinda off on a tangent, but they do make strange noises.
Did Toshiba get out of the DLP game???
3answers
Humming noise when turned on
The montherboard doesn't have anything that would make a humming noise. In all likelyhood it's the fan that sits on top of teh processor. It could be normal, but might need to be replaced or cleaned.
Toshiba 62" DLP Cinema Series
Could be the cooling fan. Is it under warranty?
-Kevin
3answers
Our toshiba 42" DLP makes an incredibly loud fan noise sometimes. Sounds like it will blow up. Can this be fixed without costing a fortune or do we just need a new set
Hello.
I can Honestly say this is little information. and i will try to you to a web site that i think it will help you and probably you can fix it by your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1254&p=4208#p4208
This is what i think is the problem.
id the sound is to loud i think its the Color Wheel maybe its broken or louse you need to check and see that you color wheel is not making the loud sound!
Good Luck on fixing your TV
1helpful
Loud hum and then an even louder grinding noise that sounds like something in a fan...Samsung hl r6167w
this is more than likely the color wheel is failing and needs replaced happens on dlp units frequently I would suggest replacing the color wheel should fix the problem
2answers
1helpful
Optoma ep716 continuous loud vibration noise when turned on.
the fan motor could be failing. turn it on with the top off. if one of the fans is moving slower, that'd be the one. since this is a dlp projector, the colorwheel motor berings might be on their way out as well. both need replacement.
I have a 44 inch 44nhm84 DLP. When the TV is turned on, it makes a loud humming noise that goes down in intesity twice and then finally a lesser humming noise after the picture comes on. At first I thought...
This does sound like a color wheel. To my knowlege, Toshiba does not sell the Color Wheel seporately. In short, you have to replace the Opical Block. The cost of this is very exspensive and Toshiba may not sell it to you. You may have to go through a Toshiba Service facility to obtain it. Check prices of new LCD sets before investing the money.
Hope this helps,
Skyassoc
1helpful
5answers
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
9helpful
7answers
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
