When programming your Comcast universal remote for your TV, the programming guide states that you should enter the 4-digit code provided for your equipment, and if you did it correctly, the TV button will blink twice.
What you have to do is put a "1" in front of your 4-digit code, making your code a 5-digit code. For instance, the code for my Panasonic is listed as 0250. I tried and tried. Then I entered 10250 and it worked perfectly the first time. I did it again to make sure I wasn't seeing things, and it worked.
Good luck.
The adding the 1 in front of the 0000 supplied to program for my sony bravia worked thanx.
I put a one in front of the code for comcast for a philips tv and it worked thnks
Does anyone know the Comcast Remote control code for a Sherwood RX-4109 receiver?
Does anyone know the correct code for the comcast remote to work with my yamaha htr-570?
SOURCE: remote
Hi jimvandy
Most yamaha codes will work some of your unit functions. try 0176 or 1176. These are for a dvr3 comcast remote. You can get the whole list and manual from here
I am more than happy to answer
any other questions you may have about it, just give me a hoy :) If you
still have problems, before you give a rating for this advice, please
get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you
as sound, a FixYa rating is a great reward for my efforts to help
you. Cheers.
regards
robotek
the comcast remote i have, doesnt work my yamaha htr 5740 with the provided codes from comcast
i'm having the same problem - need remote code for my comcast remote to control my yamaha htr-5740
Same problem. Searching for codes does not work, nor do codes published by comcast
I can not find any remote code to work between my Comcast remote and KLH R3100 receiver.
This worked for my Samsung TV, not for Emerson, but I will try to figure it out, thanks!
I have a 32 inch ILO tv and can't get the comcast remote to work with it. I have tried everything. Does this remote have a code that works? My OK button is grey.
I have a 42" ILO tv and can't get the remote to work for it. Does anyone have a code. I tried using the search option to get the remote to work the tv and it didn't work
what is the code for a sony dvdv player
what controlers do you have? black controler, grey with grey center ok/select button, or grey with red ok/select button
