Hello Either the fill solinoid is bad or the inlet tube at the ice maker is frozen. Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Check water supply and pressure is. o.k (behind the fridge). The ice maker water solenoid is located at the lower rear of the refrigerator.Disconnect the tubing that goes up to the ice maker, and wait for it to cycle.You may have to cycle it manually. If the solenoid buzzes but no water comes out, the solenoid is bad. Replace thesolenoid. (Solenoid will get energized only when previous ice made cubes are not disturbing the shut off arm. Hence make sure you have emptied the ice bucket)
the unit need to be replace some time its start leak and the only solution is to get a new one unless something got stuck in it and the water just coming out...the part# is 2198597 i think and it is 160$ at sears parts www.911servicetoday.com
Check the ice maker first by filling with tap water. Let freeze and if it cycles and dumps the dual water control valve on rear is defective. If ice maker does not cycle then I think you have a problem with the ice maker. Thanks, Sea Breeze
Look for that model number.
It’s more likely that your 61005626 Dual Outlet water control valve has become defective on the side that turns the water on for the ice maker. Sometimes the ice maker is the reason for this problem. The ice maker has a temperature thermostat that sometimes goes bad and will not tell the water control valve to come on after dumping the ice and the end of its cycle. The part number for the temperature thermostat is 627985 you can test the ice maker to see if the thermostat is bad by filling it with tap water and allowing the water to freeze. If after freezing the ice maker cycles and dumps the ice but does not refill with water then the water control valve needs to be replaced. Try that test and let me know what you find, Thanks, Sea Breeze
Hi, Check the inlet tube that comes through the back wall into the ice maker. See it has froze shut. If there is ice in the tube, thaw it out and let the ice maker cycle. Plan on changing the inlet valve if the tube is plugged. If the inlet is not plugged, let the ice maker cycle and listen for or test the valve for 120V. If there is a buzzing sound or you are getting voltage and no water, remove the tube frrom the valve that leads to the ice maker and see if water comes out of the valve. If no water comes out of the valve, change it. I hope this helps you. Please let me know if I can assist you further.
You need to check the thermostat setting. If its set too cold it will never dump ice. Warmer the setting the more ice it will make.Also check the temp. If it should be 10-15 degrees. If its 5 degrees then turn thermostat to warmer setting.
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
