Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
i want help you but the casio say right to you. the proble is that the sand is go into the lens block.. you can make this.. if you have a friend that have a little eletronic knowledge.... its possible to find the entire lens...on ebay international seller... write on ebay. lcd casio ex z77 look here on this link http://cgi.ebay.it/GENUINE-CASIO-EXILIM-EX-Z77-GOOD-LENS-FOR-PARTS-/180536724405?cmd=ViewItem&pt=Digital_Camera_Accessories&hash=item2a08d3cbb5 you have ont his link the lens for your camera the cost is 36 us dollars complet with shipment... so if you look now on you tube and write.. (casio objektiv umtauchen) you can see exactly how you have to do to replace your lens. i am sorry that i am italian if you was here i can help you better, but i hope to have help you sorry for my bad english
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
you might have pushed the lens into the barrel. small lens barrel has 3 metal pins that ride inside the
larger lens barrel as it twists. Pushing it sometimes cracks the plastic
holding these 3 pins in. one way to fix it is
to carefully disassemble the entire lens barrel. be careful...sometimes a part just snaps, or is already snapped. The easiest
way would be to replace the lens assembly with a good one you can get from another camera like this. There are no spare parts for cams like this so you can try to get another cam that has a different damage other than the lens barrel.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
this is a common issue the lens gears are stripped. you have to change them out. if you do not fell confortable doing this it is recomended to take it to a digital camera repair company the only proble with that is like most people find out is their is not that many of us around and even if you do find one they might not work on casio. I do and their are a few others. hope this helps.
