SOURCE: Handset is lit up but unresponsive
posible or you need to intial reset the whole system completly make sur all your hand set indicate on the base make sure the power is reading ok
SOURCE: wdect 2315+1
Check if the screw of the phone is not too tight, because the button might press by itself if it is too tight.
If the problem is not solved,what I do in a situation like this is to loose the phone and use cotton wool or soft brush to clean it with a little mentholated spirit, leave it in the sun to dry, after drying, allow it to cool a bit and couple it back.
You should not clean the screen with spirit, you should clean only the board and the keypad also. Just a little spirit and don't let it be too much. You can dry in any other heat apart from sun and don't allow it over heat.
I wish you the best.
SOURCE: I need help with handset
not sure if you have already got a solution for this problem as it was also listed in the Premium section until a few hours ago.
You must ensure each handset is charged for atleast 20 hours.
Best to de-register each handset first. Follow the menu on base or handset to select de-register.
Then follow the registration process for each handset using the menu function.
Hope it works this time.
SOURCE: I need to deregister missing handset #1
To de-register HANDSET #1:
1) Grab any working handset which is registered to your base (so HANDSET #2 or #3 in your case)
2) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
3) Choose the "Deregister HS" menu option
4) Pick HANDSET #1 as the handset ot de-register (since that's the "phantom" registered handset)
5) Once de-registered, you can de-register handsets #2 and #3 directly from each handset's "normal" menu interface (i.e. press "Menu", choose "Deregistration")
6) Thereafter, if you re-register your handset, they should start at HANDSET #1, then #2, and so on.
