My Kenmore front Loader started leaking from the bottom during a rinse cycle - I have already had to replace a valve in the back - What could this be?
I want you to run an empty load, pour 3-4 cups of white vinager into the soap dispencer, this will flush out detergent buildup, it sounds like the unit has a buildup of soap and is oversudsing, the vinager wash will stop it from happening, if this stops the problem cut the amount of soap you are using in 1/2. If it does not let me know, good luck
Enough to make my Floor wet along the side of the washer- it drains off the pedestal. I use HE liquid detergent. Do not have a softener
