Sony Grand WEGA KF50WE620 Television Logo
Posted on Jun 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sony LCD Projection TV has blue pixilation occuring.
Blue pixels occurring mostly at top left of the screen, but now seems more like a blue haze which is now spreading towards the center and other portions of the screen. Very noticeable when screen depicts a dark environment. I was told that the optical block might need to be replaced, wondering if this is the case, and if there is a relatively inexpensive method of repair.
John Riley
Level 3:
  • Master 441 Answers
  • Posted on Jun 07, 2010
John Riley
Master
Level 3:
Answers
441
Questions
Helped
138500
Points
1344
This is not a cheap fix, but call sony they know about this problem and have sent out new TVs to people who have had the issue, I have had about 7 out of ten people who call into sony get brand new sets FREE, so tell them that your optical engine need to be replaced at around $900-1300 and how old it is and the S#, they may not do anything for you but I would try, good luck
2answers
Yellow haze on screen
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Small blue dots clustered when the screen is dark, near the projection point.
Blue color on bottom screen and it is getting
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. You can find it here: http://www.discount-merchant.com/SONY-1-788-155-21-p/1179590.htm?Click=48173 Have a blessed one!
2helpful
Blue tint across screen and black shadow of sort
I replaced the main lamp 6 months ago. Now I have blue on the right, yellow in the middle and normal color on the left. I also have a ghost image of tree branches on the whole screen.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Found it here:http://www.discount-merchant.com/SONY-1-758-484-22-p/1180916.htm Have a blessed one!
5helpful
We have a sony wega KFWS60. It is displaying a blue film on the bottom of the screen and have noticed 1 blue pixel in the middle of the screen. Can you help Therese Smith
Do you mean KF60WE655. I don't recognize the model you show. I'm sure your talking about an LCD rear projection Sony. Your trouble is in the Optics ( light engine). Over time the Lamp has destroyed an internal filter ( glass element ) . This Blue haze or film will probably continue to get worse and grow across the entire screen. The only fix is to pull out the Optics and send off to Sony or another re builder.
Up until June 30, 2008 some of these models were being fixed at no cost by Sony.
2helpful
Sony KDF50 rear projection TV with a Blue tinge (haze) on screen
You have a problem within the light engine. This a hugely expensive. If the set is not too old you could contact Sony and see if they will help you out. Otherwise it is not eceonomical to repair
Blue haze on the lower part of rear Projection TV
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Blue haze in lower left corner on screen
if you have any speakers near the screen the magnet may be causing the problem. i had a similar thing happen & when i moved the speaker the problem went away
4answers
BLUE HAZE
That could only be the optical block, Sony p/n# A1084662a and heaven help you if it needs to be replaced. It is the single most expensive part of the DLP based projection Tv's costing approximately $900.00 dollars plus core and shipping..
You'll need to take this one to a quality repair center to have it estimated. It may be that they can repair it also - but whatever the case these type of repairs are not cheap.
Please don't kill the messenger...
Good Luck!
Bill
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
