SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this. Let's solve it before you rate it.
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Sounds like the water valve has a small leak and continuously drips water onto the icemaker. Have the water valve checked and if necessary, replaced.
SOURCE: Ice maker won't make ice after emptying ice bin manually.
make sure you push the ice lever back down
SOURCE: ice maker doesn't turn out the ice/
Top 2 possiblities
1/ The motor that ejects the ice is shot.
or
2/ the heater element that melts the ice into pieces.
Here is where you can probably pinpoint problem.
Making Ice
When everything is hooked up, the icemaker begins its cycle. The cycle is usually controlled by a simple electrical circuit and a series of switches. In the diagram below, you can see how the icemaker moves through its cycle.
-->The icemaker has a heating coil underneath the ice mold.
This system is effective for making ice at home, but it doesn't produce enough ice for commercial purposes, such as restaurants and self-service hotel ice machines. In the next section, we'll look at a larger, more powerful icemaker design.
