SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
SOURCE: Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
SOURCE: Ice building up in fridge
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
SOURCE: variance in freezer compartment temperature
How to check
everything
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
