Craftsman Convertible 25cc. Gas Line Trimmer Logo
Anonymous Posted on Jun 06, 2010
The Craftsman Sim-Pul string trimmer starts and runs for one sec.
The plastic tube has pulled out. Is it supposed to be connected to the funnel shaped fuel filter inside the tank?
Roy Cagle
Level 3:
President:
  • Craftsman Master 1,545 Answers
  • Posted on Jun 11, 2010
Roy Cagle
Craftsman Master
Level 3:
President:
Answers
1545
Questions
Helped
913219
Points
4781
The larger line is the fuel return line from the purge bulb and should have the nylon connector (funnel thing) on it holding it in place inside the tank so the line won't pull out.The smaller diameter fuel tank line goes from the tank to the lower pipe fitting on the carburetor (fuel intake line). This line has a weighted fuel filter inside the tank on it.
New fuel lines are recommended every so often as the ethanol added to our gas nowadays wreaks havoc on the lines and carburetor as well. Get new lines...cut them long....feed them thru holes in fuel tank...grab with tweezers or needle-nose pliars....put on either the fuel filter or the nylon retaining nipple and pull the one with nipple down to bottom of tank...one with fuel filter can stay long to help draw fuel in the tank (yes, it moves around and is supposed to).
Testimonial: "Thank you VERY much...it was most helpful."
Why does the fuel not stay in the primer bulb, when I prime the craftsman weedeater with sim-pul
Fuel lines probably need replacing. Have you been using ethanol? The alcohol eats the fuel lines on most 2 cycle motors up.
2helpful
I have a craftsman 32cc weedeater model 316791810. I am not sure how to replace the trim line. Is the line supposed to automatically length itself when the line breaks?
An auto feed line system will do just that and if too much line is released there is usually a cutter inside the edge of the plastic guard covering the string head. I use a Troy Built head on a 32 craftsman and I unscrew the bump knob ...twist and pull out the spring loaded spool....cut a lenth of line 6-8 feet or so....thread the two raw ends thru the two holes in the inner spool....pull them out until they are even with each other....then grasp each one and hold them side by side and wind them onto the spool in a clockwise manner. This is how I do the string head with a split boom that fits the 32cc Sears Power head (an older Troy Bilt).
Putting new pull string on Craftsman trimmer
it does screw on take a channel lock to grab the clutch and turn left to remove it
7helpful
I'm having problems figuring out how to change or repair the string pull on a craftsman 22 inch gas hedge trimmer. It looks to me like you have to remove the clutch. How do you do that?
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Engine starts then stalls
three year old craftsman 25cc simple pul edger starts but bogs out when i switch to run
The pull string will not pull out to start the
Remove the starter mechanism from the saw and try to turn the flywheel--it should turn freely except when the piston is rising against compression. If ok, pull the starter cord and watch for twisted cord or a damaged/split spool. Try to turn the spool CW by hand to see if it is bound up by something. Was the starter cord just replaced? If so, maybe the return spring was over-wound and can't be turned further. Hope this helps!
How to replace a craftsman weedeater gasline?
you hook one line to it the return line inside the tank
The line you used as a return line pull it back thru the gas cap hole and put that piece on one end of that line and pull it back in the tank until it stops and then hook the return line back where it belongs
6helpful
Pull String Ripped out, How to Replace?
no its not imposssible.but its not easy unless u have done a few times.you have screws around the plasic casing get them out.and pull
shaft off engine.
1helpful
How to add more line in my craftsman 32cc
Invert the trimmer pull the center of the head straight off. Wind new line in counter Clockwise direction. There should be a hole or notch to place the center of the string in. insert each end of the sting through one of the holes in the head and reinsert the spool into the proper position. Be sure that the automatic advance is movable by pressing down and pulling out more string. Cut string to proper length and restart your trimmer
1helpful
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
