Digital sound changed to ANALOG. How to change back to DIGITAL?
I have digital sound coming into the receiver from a cable box. I am using a fiber optic cable into OPT1. I accidentially hit something on my remote that switched the indicater to ANALOG. How do I get it back to DIGITAL?
I did press the MODE button and it did go back into AUTO, but still shows up as ANALOG.I did press the MODE button and it did go back into AUTO, but still shows up as ANALOG.
You can't post conmments that contain an email address.
In AUTO the unit will switch to analog in the absence of a digital signal and only back to digital when that signal is restored. Is it source-specific? I bet it is. Check that source's connections and settings.
You could have said that in the initial post.
It's probably a settings issue on your t.v., you can change where you get sound from (audio source), and it might be set to something like an analog audio source. Just change the audio to come from your HDMI. Not sure what model your t.v. is, but try going to settings, sound, and find something that looks similar to audio source, and change your settings from there.
Hi, This is a common problem. Each input will default to analog. Even though you have plugged an optical cable into the inputs of the Receiver, you have to change that input to digital. For example, if you connect a CD player RCA cables to the Receiver. The receiver will recognize the Analog signal at the CD input. If you unplug the Analog RCA Cables and plug in the Digital optical, the receiver will still be at it's normal default input for the CD player which is Analog. You then have to switch the input, using either the remote or it may be able to be done with the buttons on the front. As soon as it is changed to Digital, you will get nice sound. Hope this helps, Happy New Year, Mark
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
OK. This should be simple. If you are using a TV with a built in digital tuner like all the HDMI ( High Defintition Media Interface) flatscreens then you probably need to go through your set up menu on your Digital TV and select Initial Setup / Channel Input / Cable / Satellite if coming directly from a dish on 75 Ohm Coax / or Cable if coming directly from the outside 75 Ohm coax with analog signal. ( When I say DIRECTLY, I mean you are not going through any boxes and changing or passing the signal). All satellite direct connects are digital and all satellite converter boxes have multiple out puts these days. There is an HDMI output for high def and low def analogl to digital (A/D) signals coverted within the TV, sometimes there is a DVI or even a USB out put connector...and there is a 75 Ohm coaxial RF cable connection for all the old schoolers who do not have a widescreen digital TV. RF means Radio Frequency and uses Radio Frequency Channels 3 and 4 at the bottom of the RF band around 56 MHz to which any TV with an Analog Tuner can use. In the old days this is what was used for the connection to the TV from the cable boxes because our TVs did not have the capability of decoding analog pay channel signals, hence the little black boxes sold and used ONLY by cable thieves and not any of us here on fixya. For starters, let's make sure you are using your high def, dvi. or some format of digital It sounds like your TV is set up to search and code digital signals but is looking for the wrong carrier frequencies, meaning it is either looking for decoded digital satellite box signals, digital broadcast ( New Digital TV received via an Antenna). Once your TV scans for channels in the cable mode they will be memorized and available on your channel up / down keys and Favorites. (FYI t will scan for both digital and analog channels on antenna mode). Repost if you have troubles or refer to your users manual.
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM.
HDMI is mostly set to PCM while Optical is generally Bitstream.
The TV may be set to the opposite of what it needs to be.
I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass.
Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS.
Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers!
I Hope this Helps out!
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna. biigg53566
Make sure that the place it is plugged into the TV is an output and not an input for the fiber optic cable, and the place it is plugged into the Onkyo is an input and an output for the fiber optic cable. This can be connected backwards very easy. Then you want to make sure that the Onkyo is properly set on the right function to listen to the TV. Check your owners manual on how to set up the optical input and have it assigned to the function you are trying to use. Sometimes these type of receivers have an input mode button that you can set to "optical" or "analog" or "digital" or "auto". Try changing those settings after you make sure the TV optical is an "OUTPUT" and the optical on the Onkyo is a "INPUT".
After you have these thing set right you should be able to listen to it like this.
I hope this helps, if you need more help just reply back on this post, but please give more detail about the connectors and on the TV and the Onkyo, and about the digital input settings on the Onkyo. It would also help to know the model numbers of both the TV and the receiver. There is no way to check out what each of your devices are capable of doing without knowing the model numbers to look up the specs.
hook up a digital audio coaxial cable to it (not the old ones with the pin in the middle that always bends, the new one that looks like an rca cable except its orange instead of red/white/yellow). If it still doesnt play sound then your receiver is probably in analog mode. If it does play sound then its the fiber optic input.
A few questions...
What components are involved?
How are they connected?
Can you hear sound from the speakers for any other input device i.e. radio, cd, vhs, etc.?
I suspect that there is an issue with the way the system is connected.
I have the Surround sound output from my DVD player connected to the digital surround sound input on my reciever.
I'm using digital coax cable (looks like a "normal" RCA cable), not the optical fiber connection. I had to buy a special cable for the digital surround sound. A normal RCA cable would not work. I don't know why. If you're using a similar connection, that could be your issue.
make sure that the output and inputs you're using are compatible. A digital surround sound connection (in or out) can't be connected to an analog connector (in or out). Remember, Digital to Digital with a Digital capable cable; Analog to Analog with an Analog capable cable.
If this is not your issue, post back here with more info and we'll see what we can figure out.
