There was a power outage and now i am am not getting no sort of power.what part u likely think to go bad
Without any power going to the TV, it's likely that the power supply has been fried. If you feel comfortable opening the set, you should check where the power plug goes into the power supply and locate the fuse. The fuse is a small glass tube with metal rings at either end. If you take the fuse out of the holder and hold it up to a light, you can see whether or not the filament (the little wire) is still connected. If it isn't, and if the area's black or brown, then the fuse is blown and needs to be replaced.
