Compaq Presario CQ60-212US Notebook Logo
magdaline mureng Posted on Jun 05, 2010
WIreless red button is on
Why my wireless button turn red and my laptop cannot start
Anonymous
Level 1:
New Friend:
  • Contributor 54 Answers
  • Posted on Jun 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
54
Questions
0
Helped
9483
Points
95
This issue could be with the wireless driver that is corrupted.
so l suggest you to install the wireless driver from the weblink below and check it.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-76001-1&lc=en&dlc=en&cc=us&os=2100&product=3887333&sw_lang=
install the driver and restart the notebook and check
Turn on wireless
start button
control panel
wireless icon
reset it there
Turn on wireless internet connectin
If you are saying you cannot turn on wireless using a button on the laptop, then its possible it is disabled.
GOTO Start, Connect to and then wireless, this will start the wireless connect.
or
Control Panel, Network Connections, Right-Click Wireless connection & Enable.
What is the syncing process for a logiteck wireless mouse
Take your wireless receiver that is connected to your computer and turn it over. There should be a red button. Press it once (propably a led light will start flashing). After you do that, take your wireless mouse and do the same. Turn it over and press the red sync button.
Your mouse should now be synced.
2helpful
Wireless box with antena light is out i can't get wireless on laptop went to frontier my carrier they said i need to turn a reset button on the front of or the side of my laptop he insisted there is a...
Is the DSL light on the modem green or red?
Red means it's not connected to net.
Green it is connected.
The wireless light will go on when you get laptop to connect to net.
Commands to change to wireless
You should have a switch or button on the laptop to turn wireless on / off .
Do you have a little blue antenna with waves around it on the on/ off panel of the laptop(above the keyboard?
You should have the little computer with a red X in the bottom by the clock.
If not go to start control panel networks and sharing add wireless network it should show if not then it is turned off or not installed properly.
2answers
Wireless switch still red, wireless assistant not available
Two questions:
Q1: Do any other switches/touch buttons work? If not then follow the procedure below:
1. turn off computer 2. Remove battery and power plug 3. hold down the power button for 20 secs 4. reattach battery and power plug 5. Turn on laptop. 6. All buttons will work including the wireless
Q2: Do you see the HP Wireless Assistant icon in your system tray? If not then go to start menu and search for the above.
Once you locate it open the program and check if your installed wireless device is on or turned off. In case of the latter, Turn it on from the action list. Once your device is on the touch button will work.
I have a balance 557s laptop that the wireless wont work it shows the icon with a red x wont turn on when you push the wireless button
Sometimes when you get a red x against the wireless icon, it means the wireless card did not get an IP address from the wireless router or the router needs resetting.
To get the router to issue a new IP address to the laptop, right click on the wireless icon and click on Repair.
If this doesn't work, power off thr router for 30 secs and power up the router, wait till the LEDs on the router are on then boot up the laptop or do a Repair on the wireless icon.
23helpful
4answers
HP Pavilion dv5 how to turn on wireless capability
where you see the light for you're wireless connectivity (blue when enabled) should be red now, just tap it once to turn it back on.
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
