Is this preventing you from taking photos? Normally the camera shows you the selected aperture and shutter speed when it takes a photo. It doesn't show up on the photo itself; it's purely informative.Is this preventing you from taking photos? Normally the camera shows you the selected aperture and shutter speed when it takes a photo. It doesn't show up on the photo itself; it's purely informative.
You can't post conmments that contain an email address.
Does anyone have an answer for this? I wrote a year ago but still nothing....Does anyone have an answer for this? I wrote a year ago but still nothing....
this car is over i will be honest with you that mileage reading is way too high and misfiring means your engine is ready to knock anytime soon i believe you take it to your nearest Toyota dealer and they should be able to hep you
Try resetting the camera by removing thebattery for 15 mins. Then install the fully charged battery in the camera andgo to the menu and set the Date and Time.If this does not work then this camera needs to be sent away forrepairs. Just like a motor vehicle, some repairs to your camera require atechnical specialist to fix your problem.
Check inkcartridges. You can snap off the cover plate carefully, under it you will see a plastic film that is heat welded to the housing. look for damages. If it seems okay, take a small rubbertube that fits the small nozzle next to the ink outlet. blow into it gently. if theres air coming out somewhere or the plastic film is broken: Fix it with some strong tape or replace the cartridge.
Are you formatting the card in the camera as you're supposed to? Have you tried going into the menu and finding "reset" and followed the on-screen instructions? Do you have photos on the internal memory? If so, remove your card and format the camera to erase the memory.
it would appear that the lcd screen has malfunctioned and would need repair.... you can try power cycle by taking batteries out and press and hold power button down for 10 secs, draining all power out of camera, then put the batteries back in and try again
Not really a solution, but I think you have the same problem I do. I believe that the shutter is sticking. Mine will work for one shot every 3 or 5 power cycles (turn it off and on again)
