My TASCAM 2488 cannot boot up. When I start it, it says," cannot boot. not detecting HDD correctly. Check H-W. Earlier, the power was disconnected in the middle of recording. What does this mean? What should I do? HELP!
When I had that same problem, tried changing hard drive..Not it!!I changed cd-burner on a whim,,BOOTED RIGHT UP>>>Could be the same..Maybe when the power went off, it may have surged to much power to your unit...
Reseat the HDD cables, just unplug them and blow on them to remove any dust or anything on the cables and the connectors and plug them back in, but first make sure it is unplugged from the socket and once it is press the power button to let all the power out of it so you don't shock yourself , i hope I was helpful and it solves your issue
