Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Mower deck PTO switch will engage when pulled but stop when rele
I have a Yard Man, model 131684G. I pull up on the PTO toggle switch and the deck engages but when I let go the deck shuts off. I can hold the switch up and the blades will run but stop as soon as I release the switch.
  • Anonymous Jun 04, 2010
    I replace the switch already and the new switch did the same thing. Unless I got a faulty switch.
  • 146 Answers
The PTO switch has failed. There is an internal spring and plastic parts in toggle switches that keep them in the actuated position. It's not practical to take the switch apart to fix it, but replacement switches are readily available - probably $12 - $20. It's a good idea to disconnect the negative terminal from the battery before you do any electrical work. Be sure to put the wires on the corresponding terminals of the new switch. Good luck! Please rate if you find this helpful, thanks.
Posted on Jun 04, 2010
  • whatproblem Jun 04, 2010
    Sorry that did not solve your problem. It doesn't seem likely that the new switch is faulty in the same way. A 'magnetic' switch might act that way -- it 'drops out' if proper voltage isn't present in a circuit -- but I haven't seen those used on lawn tractors. Does the switch look like this one?
6ya staff
SOURCE:
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Where is the PTO switch?
The switch is on the dash bezel, the electric clutch is on the deck. Some clutches can be adjusted but I need the model number of your mower first.
Jul 06, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
Pto won't engage after it had stalled out when in reverse
Did you take it out of reverse? You need too look closer at the linkage and at wear it gos, look for the switch on the trans mission, it going to work one of two ways positive or negative if it work from ground unplug it and see if it will work, if it doesn't try running a wire from one side of the connector to complete the circuit .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/edward_020b3320326d263d
May 18, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
Aug 14, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
Blades will not engage, belt not broke but is very old, do I need new one?
Check if the belt is loose. With the engine off, try to pull the mower deck belt around by hand. If you can pull it easily, and the blades don't turn, then replace the belt. If it's hard to pull, and you can see the blades try to turn as you pull it, then your problem probably isn't the belt, but the PTO clutch or mower engage switch.
Jun 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower
Most mowers have a safety interlock to prevent starting when the PTO is engaged so it sounds normal.
Jun 02, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Mower dosen't run when engaged
The pto switch is also a safety switch, be sure it is disengaged
May 01, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
454 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
