This is a classic pressure on the camera problem...or the camera is dopped. is possible if the camera have received a bump, near the power button...that the camera case is now tonear at the power button and the button touch into the internal eletronic comand. this is the cheaper cost problem. the other problem is is the eletronic button under the power button is faulty in this case you must change the eletronical circuit under the case button. this is a problem. why it is no easy to find this spares. very mutch model dont sell directly the spare parts to the privat buyer. you have one possibility. to find on ebay international one camera like your...that have another proble. a dropped camera with a brocken lens or with a brocken lcd...but with a good eletronical power circuit. if you find this camera with a low price. disassemble to first the buyed brocken camera..so you can see the internal and make you a ides of what you have to do to pullout the circuit.. if you see that you dont have enough knowledge, find a help from a friend the have more knowlwdge. unfortunately i am to far from you.. this is the system to fix with a cheaper price. good luck from paolo italy ..if you think that i have help you remind to release your opinion.. ok??? thank you
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
?· Turn off the camera.
?· Remove the battery pack.
?· Press and hold the power button for 30 seconds.
?· Allow the camera to remain without power for 60 seconds.
?· Reinsert the battery pack.
?· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
