Kyocera CS-2550 Black and White Copier Logo
Posted on Jun 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Suddenly (after 2 years) having driver problems with Kyocera CS2550. Mac OS 10.6.3, printer is on an airport network which is functioning normally. Print error every time is "The printer software was installed incorrectly. Please reinstall the printer?s software or contact the manufacturer for assistance." Have gone to Kyocera website and downloaded latest driver, re-installed multiple times, deleted and re-added printer etc. etc.
Marvin
Level 3:
Top Expert:
  • Kyocera Master 85,242 Answers
  • Posted on Jun 03, 2010
Marvin
Kyocera Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29059272
Points
266281
It is obvious to me that the problem u have is the printer is not communicating with the computer and i also think the printer is defective and is the source of this loss of communication, as to what is causing this will take a skilled tech to figure out though testing. in the end you may find it cheaper to replace than repair based on current labor rates for this type of diagnosis and repair..
  • artonweaver Jun 04, 2010
    Thanks but I have it figured out. I found a different driver on a third-party site (not Kyocera) and all is well.
3answers
Where can I find driver for KYOCERA FS1030D for MAC OS X LION ?
hi,
here;s the download center for kyocera you can download here the driver for your printer.just follow this link good luck!
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Forgot password for macbook air
Dear Sir,
Welcome to Fixya Support
Resetting Your Password You can reset your administrator password and passwords for all other accounts. To reset your password, using a partner computer and Remote Install Mac OS X:
1 Follow the procedure for using Remote Install Mac OS X
To use Remote Install Mac OS X: 1. Insert the Mac OS X Install Disc 1 into the optical disc drive of the other computer. 2 .If the other computer is a Mac, open /Applications/Utilities/Remote Install Mac OS X. On Windows, choose "Remote Install Mac OS X" from the Install Assistant. 3. Read the introduction and click Continue. 4 .Choose the install disc you want to use, and click Continue. 5. Choose a network connection: AirPort, if you are using an AirPort network, or Ethernet, if the other computer is on an Ethernet network and you have an optional Apple USB Ethernet Adapter connecting your MacBook Air to the same network. Click Continue. 6 .Restart your MacBook Air and hold down the Option key as it starts up, until you see a list of available startup disks. 8. If you chose AirPort as your network in step 5, on your MacBook Air choose your AirPort network from the pop-up list. If the network is secure, you are prompted for a password. You can enter a private network name by choosing the ellipsis (...) and typing the name. 9. If you chose AirPort as your network in step 5, when you see the AirPort status icon indicating signal strength, click Continue in Remote Install Mac OS X.
10. Click Continue in Remote Install Mac OS X. 11. On your MacBook Air, choose Utilities > Reset Password from the menu bar and follow the onscreen instructions. When you finish, quit Mac OS X Installer. 12. On the other computer, click Quit to exit Remote Install Mac OS X.
I think it helps.Let Me know.
Canon MX310 - I'm trying to connect this printer to my network. Currently, I have the printer connected to an Airport Express but when I try to print from my iMac, I get a message that the printer is...
Adkinsdave, keep in mind that often having someone remotely connect to your computer with you and perform this task is easier than trying to walk you through steps and potentially missing a step. With that being said, the Airport Express was meant to make setting up a WiFi network in your own home a breeze.
We need to first determine if your Canon PIXMA MX310 has a Mac driver. According to the Downloads page at Canon.com, there are several Mac drivers available for OS X, 10.5 and 10.6: usa.canon.com - simply choose your OS on the pulldown from that website. Once your computer has the driver it needs to communicate with the printer, you can use your Airport Express to connect to the printer.
Obviously, make sure the printer is turned on and once you go through the Airport Express connect guide you should be printing in no time.
Let us know if there are still issues.
I'm using Mac OS 10.5.6 and the Kyocera KM-3035 prints my documents with missing letters, words, sometimes whole paragraphs. I've uninstalled and re-installed the driver to no avail. What else can I do?
use the generic print driver in mac and tune it with this tutorial also set the press printer on the copier and set emulation to kpdl auto... also see if you can make the driver spool...
if that doesn't work... then try moving a zipped 10 mb file from one pc to another on your network... make sure one pc or laptop is connected where your copier is... if you open the zipped file and its corrupted... then the problem isn't your copier... its your network...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Kyocera 3820n doesn't work right on my macbook OS X 10.5
if you have a mac os x operating system... you already have drivers built into your mac printer menu... try installing the generic print driver and see if that helps... sometimes it works better than the manufacturer's driver...
2helpful
Scanner problems after Mac Leopard Upgrade
check this link then make sure that you can send a 10 megabyte zip file to that folder from a regular pc with permissions and you can open it without corruption from the mac... if you cann't then you have network problems
1helpful
2answers
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
MAC problem with km-3050
What MAC OS are you using? I don't remember for OS 9 and earlier but if you are using OS X I can help you out. First make sure you are using the latest version of the print driver. When you open a document to print and select the Kyocera printer you will see the print dialog box. You need to look under the printer specific options to find the job accounting. I believe it is under set 2.
Hope this helps.
Henry
Using my airport
as far as i rember apple os, you hve to delete the printer which was connected through usb cable.
Disconnect mfc from mac. Connect the mfc to airport. restart airport and after that your mac. the mac os should find the printer.
anyway, some info can be found here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
