Question about Poulan Weed Eater Rte115 4.5 Amp Electric Trimmer
I have a weed eater twist & edge rte115 cant figure out how to string it
    New Friend:
How to string a weedeater/rtc115c
Posted on Jun 06, 2010
6ya staff
SOURCE:
Need to replace string in RTE115C, instructions feeble Checked everywhere...ready to trash and buy some other brand.
Oddly enough, the string head appears to be identical to the one for their gas model. Some poor engineering and design here. Before you buy another model, maybe take a trip to Home Depot and in the lawn and garden section you may find several trimmer parts for different models, including a Universal String Head. Try changing out the head as the stock one is a headache for many users.
Nov 19, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I have read the instructions on rethreading the twist and edge rte 115 but it still doesn't make any sense. Do you have instructions with pictures?
Usually, the only instructions with pictures for repairs like this are on a You Tube video if you are lucky. They may be diagrams with instructions available though. This problem is common with these units and I just recommend taking the old head off and getting a Universal type string head at the home improvement store as a replacement. You can look here if you feel a manual with diagrams can help. This is closest thing to your model I could find. See page 7.
http://dl.owneriq.net/c/cc3d8bf0-cc46-418b-bed8-e13da682e377.pdf
Oct 30, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Where or how can I get an owner's manual for the Weed Eater Model 115?
They can be found online. I used to know the address but don't have it any longer. Just keep looking, I know it is there...Lee
May 28, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
How long should the string be to cut effectively? Each side has about 3 inches now.
Hi, If you look at the shield around the cutter head, you'll find a blade mounted in the shield, at the back. Your line should be this long.
Regards, --W/D--
Jul 25, 2009 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Poulan Weed Eater Rte115 4.5 Amp Electric Trimmer Logo
1,922 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
