I have a Whirlpool model RBD275PDB12. I am receiving an error message:
E6 and F2
Any suggestions?
This is a problem with your electronic control board. It can be fixed quickly and reliably at www.fixyourboard.com
If you see E1 F2, there is a problem with the keypad.
Hello,the error E6 and F2 you are receiving could be describe as "Cancel Key line open".Follow the following steps
1. Check keypad connector for firm connection(Keypad connection to control board).
2. Press CANCEL if error code returns after 60 seconds,replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replay control board (also called ERC or clock).
TThanks
