SOURCE: My garmin nuvi 255w frozen...
you will find a reset button on the outer edge that you can press with a pencil or the like... don't press too hold and i believe you hold it for about fifteen seconds
SOURCE: System Software Missing on Garmin Nuvi 255W
Take a look at this site, http://www.garmin.be/missing.html
Download and unzip the software, plug your garmin in the USB and start
the updater.exe program. It gets you started again. Later on you can
use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
SOURCE: Charging a garmin nuvi 255w
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
SOURCE: Open the case of a Garmin nuvi 255w
i am wondering why you want to open it.
There are some small parts that will fall out unless you are very careful and even more difficult to put back when you try and close it up
. Other than to change the battery there are no fuses or user repairable parts inside.
SOURCE: Need to know how to charge garmin nuvi 255w using
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
There are three ways to charge the internal battery in your automotive GPS
unit.1
1 - Please note
that temperature can play an effect on the charging of a device. If the battery
registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
respectively) then it will not charge. When connected to external power it will
only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a
USB cable.
