SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
SOURCE: Lost manual for the GE DECT 6.0 Cordless Digital Phone # 28115FE1
GE 6.0
Somehow I have put "DO NOT DISTURB" and now I have no ringer
Any solutions or suggestions?
SOURCE: tesco ARC200 Cordless DECT Phone
[ARC20x User Guide p20: 11 Handset Registration]
To register a new handset:
If registration fails...
-> The display shows "BS 1234". If any of these numbers is steady (not flashing), then the handset is already registered to that base unit.
-> The display shows "BASE PIN _ _ _ _"
-> The display shows "WAIT _ _ _ _" for a few moments, while the handset searches for a base. Then it shows a list of handset numbers which are still free on the base unit.
(For example, "1 34 6" indicates that numbers 1, 3, 4 and 6 are free; 2 and 5 are already assigned to other handsets.)
-> After a moment, the display should show the handset's name and number.
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
