Tv only picks up 9.1 channel and all others are single digit or analog channels. how do i fix it to pickup 2.l, 7.1 etc.
Digital air signals are weak and fussy. They are easily lost by having trees or large buildings in the way too.
The best thing to do is install a long range roof top antenna and re program the set. Be sure to aim the antenna correctly. if you cannot use a roof top antenna you can try the indoor digital antennas,but less likely to work consistently
Odd. That really does sound like a reception issue, ie your signal isn't as strong as the TV needs. You may be able to boost it with a standalone digital antenna (the digital tuner in the unit isn't the best) but as has been mentioned, a separate rooftop antenna or even a descrambler would be more helpful.
Please elaborate on the age of the tv. If it is an older tv it is analog, and wont pick up stations that are all digital.
