Question about Sony Handycam DCR-TRV22E Mini DV Digital Camcorder
TRV22E When i try to put images from a tape onto a cd the images are fine but i get no sound when i play the cd back. when i'm transfering from the camcorder to the computer i can hear the sound through the camcorder so i know it's there but not when i play the cd back
  • 2 more comments
  • jaidenleigh Apr 09, 2008
    Iam using Imagemixer ver.1.5 for Sony
    I Have been to the site you gave me and downloaded the correct driver but it makes no difference, i still have the problem
    i am connecting it to the computer by USB cable and then following the step by step instructions that came with the camcorder.Imagemixer starts when i connect the camcorder, i choose EZ Video CD, put my new CD R in the CD drive select the CD R drive and writing speed and click start.Like i said before, i get the pictures when i play the CD back on both the camcorder and my DVD player, but no sound.
    It's Working !!!
    Thankyou so very much for your help.
  • 123 Answers
Are you choosing capture enviroment and then choosing movie file display button?
Posted on Apr 09, 2008
  • 1 more comment
  • Anonymous Apr 09, 2008
    How are you connecting it to the computer? What are the steps you take when you use imagemixer?
    Try going into Capture Recording Preferences inside of Imagemixer. Check what it says under "USB Capture Device Setting." Try choosing the option "USB Audio Device" from the drop down window.
    No problem, glad i could help.
    Sergeant:
  • 317 Answers
Because its only an images..file... the file have sound and images is video file...
    Genius:
  • 1,142 Answers
Please provide the model and the make
6ya staff
SOURCE:
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
No sound
Dear Jaidenleigh,
Problem seems to be in software settings in your PC. Give a close look to software and try to understand its properties.
Apr 08, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
No sound
Hi , try to play your old video taken if still have no sound , if the same no sound the audeo system has a problem.
If having sound in old video collection , the tape that you are using now are having deffect connot record sound. replace a new tape, and try record again.
Jan 15, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Making video cd
On your computer you need to enable the USB sound card from the camera.
Dec 19, 2007 | Sony Handycam DCR-TRV22E Mini DV Digital...
How do i put a tape recording onto the pc?
Unless the video is stored on the memory card you cant transfer it directly, you need a video capture device, it is an attachment to your Computer that manages the transfer of taped video copies to digital...
Dec 09, 2007 | JVC GR-D60 Mini DV Digital Camcorder
This machine plays DVD discs fine but can only hear the sound with VCR tapes
Try first to clean the video heads then if that dosent work take in the machine to have the heads professionally cleaned. God Luck
Jul 27, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sony Handycam DCR-TRV22E Mini DV Digital Camcorder Logo
85 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
