Probably thermostat problem, although some chance you have one side of a 220vac breaker not working. In otherwords oven heating element is "getting" half of the required power. Call electrician!
The problem is usually down to the thermostat - sometimes it can be moved and end up touching the grill and burning out - other than that they just wear out after time with the heat.
Have a look here for a spare - its easy to replace if your husband is half competent with fixing things.http://www.espares.co.uk
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Oven functions Oven light. Upper and lower heating elements. (Conventional cooking). Upper and lower heating elements with fan. (Fan assisted cooking). Lower heating element with fan. Inner grill heating element. (Radiant grill). Full grill heating element with fan. (Fan grill) Rear circular heating element with fan. (Fan forced cooking). http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
