This is my first time that i configure asus wl-320g access point then i don't know how to configure it. Do your have any support to me for configuring asus wl-320g access point?
I'm Sam Carriedo in philippines
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Your AP should have a lan port. Plug in an ethernet cable to the lan port. Wait 10 sec.
Open command prompt window. Type "ipconfig" without the double-qoutes. It should tell you your current IP address & the gateway address. The gateway is the AP.
Open a browser such as firefox. Type in the gateway address (often they are 192.168.0.1 or 192.168.1.1). A login screen should appear. Enter login info & a wizard should walk you through the rest of the process.
Good luck.
