Question about Craftsman Convertible 25cc. Gas Line Trimmer
Weedwacker won't start
Craftsman 17" Weedwacker
Was working last Fall; however won't start. Any suggestions?
  • Craftsman Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 02, 2010
Testimonial: "Wonderful response that I will follow-up on. Also, very quick, and complete"
6ya staff
SOURCE:
While trimming a type of brush wrapped around the cutting head and made the unit stall, upon clearing it the head now is weak and does not spin with enough power to cut; how can i fix this?
Remove string cap and tighten nut or you will have to hold shaft just above string head with pliers and turn head by hand till tight.
press the helpful button and check link below
Craftsman 17 25cc Weedwacker
Sep 15, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
Aug 04, 2015 | Cars & Trucks
My 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Nov 15, 2011 | Garden
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
Craftsman weedwacker 31cc 17" won't start has spark fuel it has been sitting for years
Have you checked the condition of the air filter? If ok, have you cleaned and re-oiled it?
My 31cc 18" Craftsman weedwacker came with the house I bought 5 years ago. Just getting around to getting it going. Checked air filter and found it had disintegrated. The air filter is foam and you put oil on it so over time the foam will break down. My manual states that if you don't clean and re-oil your air filter every 10 hours of operation, you void your warranty so sound fairly important. Just picked up new air filter yesterday. Will let you know how mine starts up (or doesn't) later today or tomorrow.
Jun 20, 2010 | Garden
Runs fine when first start. Dosen't want to start after warmed up.
Have you checked or Changed the Fuel Filter.
It will be in the tank hooked to the fuel line. I suggest a small pair of Hemostats for this job.
May 25, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Engine on Craftsman Weedwacker will not turn over.
I assume the tank has gas. The first thing to check is for spark at the plug. Remove the plug from engine, connect the plug wire to the plug and ground the side of plug to metal engine housing using pliers with plastic grip handles so you don't get a shock. Pull the starter cord and watch the plug for a spark jump. If you have spark then it is likely a gas starved situation. All these small engines should be run dry before storing in the fall of year to prevent carb from gumming up over the winter. Anyway remove the gas line and drain any gas from carb and drain tank too if it has old gas from last year. Replace fuel line and spark plug. Using new gas and 2 cycle oil, plus an ounce of STP gas treatment, refill tank. Work the primer bulb several times and pull the throttle several times, then pull cord. Keep repeating to see if you get a start.
May 16, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Convertible 25cc. Gas Line Trimmer Logo
1,139 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
