Hoses were too degraded for me to actually determine the pick-up from the primer to the carb sequence
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Look carefully at the 2 nipples on the carb. You can tell one is slightly larger than the other. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. completing the purge circuit. This info pertains to the Craftsman 32cc with Zama carb and may work on the 25cc model as well.
Testimonial: "local lawnmower shop told me wrong and I knew theoretically it wouldn't work The info gained here now makes sense of it all!"
