When I turn my tv on the green light comes on then blinks red.
Sony wega won't turn on 3 red blinks KDF -50E2000 when I turn it on it turn green but quickly turns red. Can some help me
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
When turning the tv on the green light blinks for a bit than the red lamp light starts blinking and than it turns off? What to do
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
SOURCE: turn tv on tv nothing happend red light blinks 3
O would need the model number to assist you, as the s blinks is an error code, but error codes are model specific.
SOURCE: I have Sony tv model KDF-42WE655 which stopped
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
SOURCE: when i turn on 3lcd wega engine tv the green light
change lamp.the lamp # is XL2100U THE BEST PRICE IS IN LAPTOP FOR LESS.www.laptopforless.com is complete lamp & housing $93.95
