What does a bios beep code of one long and 9 short beeps identify on a ASRock SLI eSATA2 mother board?
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short
DRAM refresh failure
2 short
Parity circuit failure
3 short
Base 64K RAM failure
4 short
System timer failure
5 short
Process failure
6 short
Keyboard controller Gate A20 error
7 short
Virtual mode exception error
8 short
Display memory Read/Write test failure
9 short
ROM BIOS checksum failure
10 short
CMOS shutdown Read/Write error
11 short
Cache Memory error
1 long, 3 short
Conventional/Extended memory failure
1 long, 8 short
Display/Retrace test failed
AMI BIOS beep codes
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to: http://www.computerhope.com/beep.htm#04
