SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Intermatic T103 timer wired for 240V
yes u will, but u will have to make sure one of the motor wires are hooked up that way also, in case it has been moved, here is a link with the diagram u need
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t103%20-%20english.ashx
SOURCE: swimming pool time clock face doesn't move
The timer has internal switches that you connect the input and output to . That is the NO, C , NC set of contacts. It also has a set of terminals for the clock, usually the first terminals on the left. Before connecting a feed to the clock, confirm the voltage rating for the timer. the clock voltage may be different than the contact voltage.
SOURCE: intermatic timer for my pool pump - clock is not running
Usually the timer motor is bad when that happens. Replacement timer motors are available from websites like this one:
http://www.aplussupply.com/intermatic/timermotors.htm
Be sure to get the right voltage timer motor. Intermatic T101's and T103's use a 120 volt timer motor (Cat# WG1570) and the T104 uses a 240 volt timer motor (Cat# WG1573).
If you don't want to mess around replacing the timer motor, you can purchase a new timer, and as long as the existing enclosure is in good shape, just swap out the guts.
SOURCE: clock for pool pump intermatic timer Model T104P3 stopped ticking
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY ..LOOK EBAY FOR .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX
