Kenmore 24032\24036 Top Load Washer Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kenmore 80 series washer at the end of the spin cycle or when the lid is lifted it will lurch from side to side.
Anonymous
Level 3:
President:
  • Master 1,937 Answers
  • Posted on Jun 01, 2010
Anonymous
Master
Level 3:
President:
Answers
1937
Questions
0
Helped
429809
Points
5400
This assumes that you have a KENMORE top load, direct drive, neutral drain washers are made Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle OR when the lid is raised during the spin.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Kenmore 80 series washer model 110 doesn't fully drain when cycle complete
With the lid open, try to turn tub by hand. If you can you may have a bad clutch. If you hear the washer agitating at the begining of the cycle without any water and filling at the end of the cycle, replace the ATC switch. Try spin cycle and open the lid, if you don't see the tub turning, but hear the motor, check motor coupler, or if it never spins after you close lid, check lid switch. These are the most common solutions to this complaint.
My Kenmore 26442502 top load washer will not kick into the spin cycle after it agitates. Just kinda humms. As I open the lid while it should be spinnning, everything stops, like it should. Once I close the...
Hello Dbriner,
It would appear that the lid switch is defective and is in need of replacement. I included a video showing basically how to replace it (It is a series 80 machine but that is minor).The steps are the same.
Your part can be found here for $29.65 +Shipping
Good Luck!
Rich Lilja Kenmore Washing Machine Lid Switch Assembly WP8318084
2helpful
Kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
1helpful
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Machine stops after wash cycle, restarts when i bang the lid.
sounds as if hte lid switch is not activating correctly, the lid actuator is actulle hte under side of left hand door hinge. if you lkift the lid and feel under the left side og the lid you fell the metal lid hinge, simply slip a hollow shafted screwdriver over the hingeitself and bend slightly back, this will make the lid come in contact with swict a little bit easier
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
1helpful
3answers
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Alexander
vince
