SOURCE: Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
SOURCE: Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
