Bosch 23 in. SHU 8805 Built-in Dishwasher Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch SHU6802 dishwasher quit part way through wash. No lights showing and no response to off/on switch. Power is on at dishwasher input. Where can I find a wiring diagram?
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on May 31, 2010
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3798885
Points
33142
Go to searsdirect. enter your model number and you can access a complete parts diagram and wiring diagram. http://www.searspartsdirect.com/partsdirect/subcategories/2088/1935/Dishwashers
J.
Bosch dishwasher won't start, error code h:05
Could have a timer problem or switch
No indicator lights
A Bosch washing machine can make your life easier. Look in the troubleshooting section of your owner's manual for specific information related to the make and model of your Bosch washing machine.
Find more details on Bosch Home Appliances at Appliances Connection online.
Make sure the washing machine is unplugged or the circuit breaker is turned off before you attempt to replace any parts.
Bosch shu6802 use and care manual
Oops! whats your question? If you need a manual, you can go on the Bosh web site to request one.
If your electronic board is giving problem....and the machine is more than 6 yrs old, and the user manual does not help..be prepared to buy new. The Bosh are good except when to board goes...
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
BOSCH DISHWASHER
Check the sensor of the liquid at the bottom of the dishwasher. Sometimes that is the cause of the fault.
Bosch dishwasher
hi there first i would confirm you don't have power supply issue, replace the fuse and try different power outlet failing that it is quite common for bosch on/off switchs to burn out.
hope this is of some help
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
