eMachines E19T5W 19" Monitor Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blinking blue power light and greenish tint....
About a week ago the screen get a slight greenish tint to it, but not enough to stop using it. The discoloration was uniform over the entire screen.
Then yesterday when I turned it on it went off, and the power light started blinking. It was like it was "starting up" over and over again. Finally it came on all the way, and stayed on.
Last night it went into sleep mode and it did the same thing this morning.
I read another post about the power light blinking meaning "bad caps" on the power supply cord, but that post didnt' say anything about a discoloration, so I thought I Would try to see if anyone knows what this could mean.
Thanks in advance! :)
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on May 31, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557207
Points
31058
Is the monitor still under warranty? (probably only the first 12 months)
Try connecting the monitor to a different desktop/notebook computer, to see if it is fine.
If it is, you have a problem with the video-card in your computer, not a problem with your monitor.
There are "capacitors" inside the monitor, that serve to supply "smooth" and "ripple-free" power to the electronic circuits. If you have "bad" capacitors, they are not doing what they should be doing, which causes the electronics to malfunction.
So, if your monitor is a CRT monitor, it's time to responsibly recycle it, and buy a new one.
If your monitor is an LCD monitor, take it to any TV/video repair shop, and pay them $25 to $50 to "inspect" it, looking for "bad caps". Or, spend that $25 to $50 to buy a new LCD monitor.
My KDS-R70XBR2 has a yellow greenish tint
It if the screen is where you see this is likely a bad optical light engine that this set uses. A photo of this taken and posted here would be helpful---the site also has a new feature where you can take a video and upload it with a question.
2answers
Bluing at bottom of picture.
take away if there was any speaker near the tv Unit. you need to demagnetize the screen using a magnet or demagnetizer.
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
3helpful
Greenish tint on my Hitachi x1250 Projector
the light polarizer on the blue lcd panel is fried due to excessive dust and heat. you'll have to replace the entire optical engine.
3helpful
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
1helpful
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
BLOTCHES ON SCREEN
This may not be the problem, but the following service bulletin may be of interest:
Last Update: 1/25/2006
Document Reference/Event ID: E30094243
Model: KDSR50XBR1, KDSR60XBR1
Subject: Picture might have a slight Greenish tint.
SYMPTOMS
Under certain conditions (especially cold/ first power ON), white areas of the picture may take on a slightly greenish tint after power on until internal temperature stabilization is achieved. Typically, this disappears after approximately 10 minutes operating time, however, in certain cases (i.e. colder conditions) the set will continue to fine tune the picture longer that 10 minutes. This is in order to create optimum picture performance under nominal viewing conditions.
This is not a defect but a characteristic of the LCD panels. Be assured that the time it takes to disappear will neither lengthen nor reduce over time.
If the condition improves but reduction in effect is desired, there are customer adjustments that can minimize this condition. Please demonstrate these adjustments with the customer, to determine if these settings are acceptable. (User adjustments are supplied in Solution A)
In cases where no Uniformity improvement is achieved (after 30 minutes power on time) proceed to Solution B; Optical block
Note:
Please be aware that all Optical Blocks exhibit warm-up behavior.
Replacing an Optical Block will not eliminate or significantly reduce the time below 10 minutes.
RESOLUTION
CAUSE:
Internal temperature stabilization needed.
Solution A)
You may reduce this effect by changing some user settings as follows:
(1) Change the Color Temperature setting to Cool - (refer to page 81-82 of the instruction manual). If further reduction is desired proceed to step 2.
(2) Slightly Reduce the Green bias (only available in PRO Picture mode under Advanced video settings), then select white balance Adjustment - (refer to page 81 of the instruction manual). Example:
a. Menu, Video, Picture Mode, Pro Mode
b. Menu, Video, Advance Video, White Balance, G-Bias (Reduce several steps)
Solution B)
Replace Optical block after gaining approval from Sony Tech. line.
SLIGHT GREEN TINT TO PICTURE
most atimes if i adjust the screen adjuster on the voltage multiplier i always observe that the screengoes green(lg 21" television),and if i readjust the screen,the greengoes off.Rubberhead,try adjusting the sceenknob on your voltage multiplier(line transformer).
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
