Question about Bose Acoustimass 10 II System
My Bose subwoofer not working on my Acoustimass 10
The speaker system is connected to an Onkyo receiver and has worked fine. I just noticed that no sound was coming out of the subwoofer when I was watching a movie. I checked the receiver connection, it seemed ok. I ran a sound test and all of the other surround sound spearkers worked, but no subwoofer sound.
Any thoughts?
Thanks,
D.A. in Florida
6ya staff
SOURCE:
Marty marty
  • 883 Answers
SOURCE: Bose Acoustimass 6 No Subwoofer sound
take it back for refund or exchange without delay. Too many times, there are cases of faulty factory assembly. Most likely a poorly connected wire inside sub, which fell off after a few booms.
Posted on Jun 17, 2007
simplemitch
Mitch
  • 752 Answers
SOURCE: Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Posted on Aug 05, 2008
Anonymous
  • 3 Answers
SOURCE: BOSE ACOUSTIMASS SYSTEM 15 SUBWOOFER - NO POWER
All I did was unplug my surge protecter for a 1 minute and once I did that I had bass from the module again.  I am using a Belkin PURE AV power console.
Posted on Feb 11, 2009
Anonymous
SOURCE: Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Posted on May 08, 2009
Suraido
Gilbert Labont?
  • 195 Answers
SOURCE: Please Help ....i have Bose Acoustimass 10, 5.1 system connected
Usually the LFE out is only a line out and is not amplified in any way, so first of all is your subwoofer self amplified or not? Cause if not, the LFE output won't be of much use to you. So if it's not self amplified you need an new amplifier to put between the receiver and the subwoofer. Any amp that supports RCA line-in input will do. Even a car stereo amplifier will work provided you can get a 12volt power supply to run it in the house. If the subwoofer is self amplified though, then all you need is to make an adapter cause none are readily available in stores to go from a RCA connector to 2 wires. You can buy a virgin RCA connector that you can wire yourself at The Source, Circuit City, or any electronics store you have locally, or if you have an old RCA to RCA wire you don't need anymore, you can just cut it in half, strip the 2 wires and you got you adapter right there.
Posted on Jul 07, 2009
I BOUGHT A BOSE AM 10 AND ONKYO TX-SR508. IT IS WORKING FINE BUT NOT SURE ABOUT THE CONNECTIONS. ANY DRAWINGS OR DIRECTIONS FOR BEST REUSULTS FROM TV, DVD ETC TO ONKYO AND TO BOSE? HOW I CONNECT A FLASH...
The manuals that came with the units have the diagrams. You DO have them, right?
"Flash drive"? What type of interface does it have (USP)? This unit supports a dock for iPod. Page 50...
Mar 05, 2011 | Bose Acoustimass 10 II System
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
Which model of amplifier will match the Bose AM 10 series4
There's a pretty decent write up for this speaker system on CNet. The "Speaker System" section calls for an amplifier capable of 10 - 150 watts RMS.
Bose maintains a library on their products as well. You can download FAQs, Manuals and Product Information easily. On the accessories tab, Bose lists an Onkyo receiver for $350 that will work very well with this speaker system. Of course, any quality modern stereo receiver or amplifier with power in this range 10 - 150 watts should provide good results, but better amps will be in the 75 watts and greater range.
I hope this helps - good luck
Sep 14, 2010 | Bose Acoustimass 10 Series IV Home...
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
How do I connect my Acoustimass® 5 Series III Stereo Speaker System to my Onkyo SR506 av receiver?
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
Oct 28, 2009 | Bose Acoustimass 5 III System
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
Jun 17, 2007 | Bose Acoustimass 6 III System
Bose Acoustimass 10 II System Logo
621 people viewed this question
Top Bose Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
