Sony KP-57WS500 57" Rear Projection Television Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen looks as if it is 3D. The colors are all offset.
Our Sony kp-57SW500 looks like it is in 3D. The colors don't align. Is this a common problem or did our 10 month old son push some magic buttons?
Anonymous
Level 3:
  • Sony Master 3,459 Answers
  • Posted on Aug 14, 2010
Anonymous
Sony Master
Level 3:
Answers
3459
Questions
5
Helped
849825
Points
5558
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only The screen looks as if it is 3D. The colors are al - 69189a5.pngg the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
We own a Sony Sony kp-53xbr4ct and recently the image on the screen began to look like a 3d picture with red and green colors. Some research on our end points to a convergence problem. My question is...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
  • Screen looks 3D
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
My Sony KP-51HW40 shows a redish shadow behind the objects in the picture. Is this fixable? thank you ! John
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Toshiba projection tv, blue color out of alignment
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
  • Dull looking video
  • White looking video
  • Red/Orange looking video
My sony kp-57hw40 projection tv picture is not as bright as usual. There is blue arc lines that show up at the bottom of the screen.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
2answers
KP-43170 Sony Projection TV is blurry
Try this site www.my.electronicshelponline.com they have list of free schematic diagrams/service manuals including repair and troubleshooting tips. Good luck. Hope this help.
1helpful
Red lines out of alignment
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
The screen is displaying a green red blue off color display how do i fix it
Symptoms:
  • Screen Looks 3D
  • Colors wont align
1helpful
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
Symptoms:
  • Screen Looks 3D
  • Colors wont align
KP-51H1w40 has red blue lines curved across the screen about an inch or so apart, like a rainbow
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
My tv wont line up crosses and it is the same model kp-51ws510 51in
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
