There is an instruction online indicating that the wire connected to the parking breaks be connected to the earth wire instead. Not recommended as the is a safety issue.
Drive Safely!
Check to ensure the wire to your parking brake is grounded. You can also set a dead ground on the cable and the head unit will think you have the parking brake enabled at all times.
your car probably wont have one this wire is designed to be hooked to the park brake switch wire so you cannot watch movies going down road.as this is illegal. the wire gorunds when park brake is pressed. splice it into the wire on brake
this wire is designed to be grounded when oparking brake is on this is so you cannot watch dvd while driving as that is illegal. Some people wire this up on a toggle switch to a ground so they can flip the switch and make it work whenever they want. I cannot tell you to just wire this to a ground as that would be illegal!!!!!! ;) supposed to wire it to the switch on park brake this wire grounds when brake is on
Just connect the parking brake wire (coming from the stereo. it's usually a pale green) to chassis ground. But be aware that viewing video while driving is illegal in almost EVERY state!!
ground the e-brake wire to something other than the e-brake start the dvd when you hear sound press "stop stop" then enter the code 26604 then press "enter" you will have to do this every time you want to watch a movie but it works.
