If you had a bad jam, that you had to forcefully remove, prior to getting that error message, then its possible that a Paper Jam Sensor may have been damaged in doing so. Its also possible that you could even have a Hardware/Parts Failure. If your Epson Printer is still under its original one year Factory Warranty, then you can simply call "Epson Technical Support" and talk directly with a technician trained by Epson on your particular model of printer and they may be able to help you over the phone. To see available phone numbers for technical support, go on-line to Epson @ " www.epson.com ", or call the Epson Automated Support Locator @ 1-800-442-2110 [press 1, then 1 & following prompts].
