Heating & Cooling Logo
Posted on Apr 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rinnai water heater continually running
My home has a Rinnai 2552 water heater. For the past several days it has been running almost continually. It has not done this before. There is no water running and it continues to keep coming on. It sounds to me like the air intake fan is what is running but every minute or so it does ignite for less than a second and the fan stays on. There are no error messages on the remote. When the water is turned on, it works normally. Every now and then it will turn off for a few minutes but for the most part it is running continually. When I turn the water inlet valve off the unit will stop running so I am thinking there is either a pressure or temperature issue – possibly related to the change in seasons where I live? I don’t know if these units come on after a pressure change, temperature change, water movement, or a combination of these?
Any advice is appreciated.
Scott Magill
Level 2:
Scholar:
New Friend:
  • Expert 70 Answers
  • Posted on Apr 18, 2008
Scott Magill
Expert
Level 2:
Scholar:
New Friend:
Answers
70
Questions
0
Helped
55779
Points
103
The rinnai comes on when water starts flowing through the unit.
  • Scott Magill Apr 24, 2008
    Do you have a hot water circulation line? If so that will cause flow through your water heater. If not there probably a faucet that could be mixing hot and cold water through it. You can turn off valves to faucets and see which one it is
My Rinnai energysaver 557ftr is showing error code 12. It will turn on, the fan works and it makes a bubbling noise and the flame lights but then immediately goes out and the heater stops.
It is a Gas Appliance and needs repair by a qualified gas registered technician. It is a generic code for 'no flame'.
energysaver-557ftr-oim.pdf
Rinnai https://rinnai.co.nz > media > energysaver-557ftr-...
Please quote the code displayed when enquiring about service. FAULT. Ignition failure. Flame failure. Overheat. Room overheat. Room Temperature. Sensor faulty.
How to Fix Rinnai Error Code 12 - Troubleshooting Tips
home-water-heater.com https://www.home-water-heater.com > Rinnai
An error code 12 found on the Rinnai tankless water heater means "no flame" or a water heater didn't recognize a flame in the combustion chamber.
Missing: 557ftr ‎' Show results with: 557ftr
Troubleshooting Rinnai gas heater with error code 12.
JustAnswer https://www.justanswer.com > home-improvement > 7...
Jul 10, 2013 - The error 12 is a flame error code. Most customers with this issue ultimately end up replacing the the flame rods to remedy it, ...
1 answer · Top answer: It is pictured for location identification on page 7 of the manual below. CLICK
Rinnai infinity 20
When is the last time it was flushed?
How do you start the heater?
Water heaters are the part of every home in America. The one of the most common reason of that problem is your lithium battery you have used is outdated. Follow these steps to check the problem.
Closed the valve of gas from back end.
open the water heater cover
Replace lithium battery with new one
Screw in the water heater
Check it
Now it will start
Source:
http://www.rinnai.us/documentation/downloads/Owners_Manual_1004.pdf
http://water-heater-installation.net/problems-and-solution-of-rinnai-tankless-water-heater/
1helpful
Will the Grundfos RCP-96 model work with my Rinnai tankless heater model # C85e-1?
Grundfos RCP-96 has Flow range: 0 - 27.5 U.S. GPM
According to Amazon spec sheet:
http://www.amazon.com/Grundfos-RCP-96-UP515-55SFC-Recirculator-Timer/dp/B00128BJAO
Most tankless require .4 GPM to start burner and .25 GPM to maintain burner
Rinnai does not show C85e-1 so you will have to consult your manual to see minimum water flow requirement.
http://www.rinnai.us/tankless-water-heater/
Sample manual from Rainnai mentions 'minimum flow rate' several times but doesn't give specific number. Yet promotion blurb on page 1 says "Ultra operates at a lower minimum flow rate."
http://www.rinnai.us/documentation/downloads/U290-665x0200_Condensing_Manual_EN_FR_1-2010.pdf
Another rinnai manual mentions flow rate several times in troubleshoot section yet fails to define what that rate is:
http://www.rinnai.us/documentation/downloads/U287-1833_VB_Series_R75LSi_R94LSi_R98LSi_Manual_EN_FR_EN_FR.pdf
It might seem that tankless promoters are CTA by failing to mention specific flow rate numbers.
I think tankless promotion is a definite overachiever, and vague flow rate is one tiny example.
It proves the necessity of reading whole manual and asking questions before buying a tankless.
There's another factor to consider:
All performance numbers are based on new products in ideal circumstance, and not based on a 4 year old product located in your home.
Your flow rate may vary, especially over time, and especially if water in your area is not crystal clear, and you are not diligent with correct water softener and filter.
Many factors can affect flow rates: water pressure, number of elbows, clogs in the line, sediment, size of pipe, aireators, water-saving shower heads, local water conservation policies, water well pressure, MUD district pressure issues, your home located near end of a water main, etc.
Read tankless efficiency vrs water softener
http://waterheatertimer.org/Battelle_Final_Report.pdf
Image of tankless parts vrs tank parts
http://waterheatertimer.org/images/Compare-water-heater-parts.jpg
Bradford White tankless vrs tank side by side
Lime scale does not flush out of tankless
Tankless must have water conditions with less than 11 grains hardness
"Savings falls far short of a payback," 'without comparing service costs'
http://www.pmengineer.com/Articles/Cover_Story/8cf9e86f7c298010VgnVCM100000f932a8c0____
geno_3245_197.jpg Sediment clogs tankless pressure sensor without softener.
We have a Rinnai tankless water heater. It is only 2 years old. We have a very insulated home but this is outside and we have had frigid weather here in Atlanta this past week. Anyway - it does not look...
You need to loosen the inlet water line and see if water is flowing into the unit if it is then on the output side do the same thing if there is no flow get a light bulb and put it inside the unit and cover it for about two ours use a 60 watt light bulb, then try it if you still have no water then I will give you the web page where you can look at the trouble shooting chart for your model which you did not give. Also they have a tech support you can call but you have to register hope this helps and Merry Xmas and a happy new year to you. Thanks for using fix-ya.com
http://www.rinnai.us/privacy-policy/
My kids just bought an older home w/a rinnai continuum nc-45-4us. right now their house phone isn't installed, so they can't phone, but they can't turn on hot water. any suggestions
Run through the basic checks
  • Power lead from the heater plugged in a socket turned on.
  • Gas on to house
  • All valves below heater in on position.
  • If they have controllers in the house turn on (key pads marked with Rinnai logo in kitchen or bathrooms usually)
There is a turbine that spins in the heater when a hot tap is run. If the heater has been sat for some time not operating the turbine might have stuck. Run the hot tap and keep it running, using a hammer give the centre pipe connection under the heater a firm hit a few times(not too hard). This might unstick the turbine.
Top Heating & Cooling Experts
Paul Carew
john h
