Windows 7/8 or 10,, all 3 were sold new.
600-1000 model (you fail to say the full model over 6 or more)
now with generic usb keyboard, I guess.
the G button on the side,?
http://h10032.www1.hp.com/ctg/Manual/c01907056
the A button on the other side, left.
same book,
gone now this:
To change the screen brightness using the keyboard:
Press the Fn key on the keyboard, and simultaneously
press the F10 key to reduce screen brightness.
Press the Fn key, and simultaneously press the F11 key to increase brightness"
and last , page 14 touch smart
quote your manual.
HP My Display TouchSmart Edition allows you to adjust the screen display using the touch feature.
You can adjust sound, brightness, and contrast.
Viewing mode can be set to the factory default, or optimized for movie, text, or gaming.
Status indicators let you know if the onscreen keyboard scroll lock, number lock, or caps lock are set.
A settings screen lets you adjust color with the touch of a button.
An options screen lets you set display options, set transp
arency, and check for updates.HP My Display TouchSmart Edition can be accessed from the task tray, or by right-clicking on the desktop, or fromthe Start Menu, tap
All Programs, tap HP, and then tap HP My Display TouchSmart Edition. Online help for HP My Display TouchSmart Edition is available by tapping the button in the upper right hand corner of the application screen.(end quote)
pg14 read.
http://h10032.www1.hp.com/ctg/Manual/c02700774
the 600-1400 series ?
same page 14
last windows 10
https://www.isunshare.com/windows-10/2-ways-to-check-display-adapter-properties-in-windows-10.html
next time tell , what OS is there and the full 600-nnnn
what is nnnn?
windows 10 moved display GUI to Settings menu's
Windows 8 to 10 have the brightness control in the action center or power settings or look in the charms bar if your using windows 8 or 8.1 (note: if brightness doesnt change it maybe due to the OS not knowing how to change the brightness let me know if that ends up being the case)
SOURCE: side key functions on HP#5189 keyboard
Left side keys - moon-hibernating mode, club+hp - takes you to hp internet club (lots of resources,free classes, etc on hp), globe spinning-takes you to internet-yourhomepage, envelope-takes you to windows email, magnifying glass- takes you to windows live search, ?-takes you to help
right side keys- arrowup1-opens disk drive, arrow up 2-opens 2nd disk drive if you have two, solid dot-opens dvd suite, arrows left-rewind, arrow right -fast forward slow, 2 arrows right-fast forward fast, and solid square -pause these are all media functions
I discovered all of this by taking a chance and pushing the key to see what happened. really wish they put a manual, or screen showing functions for the keyboard. hope this helps someone else!
SOURCE: locked keyboard buttons
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
A Text Services and Input Languages window opens.
Figure 3: Change Keyboard button
Figure 4: Add button
Figure 5: Add input language: US Dvorak keyboard selected.
The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
Figure 6: Keyboard tray icon
Figure 7: Move up button
SOURCE: HP wireless keyboard shortcuts to internet browser
Changed the setting of the keyboard and reconfigure the key board layout in control pannel.... If required update the drivers for the keyboard... if thet does not resolves the issue run a system restore
SOURCE: HP compaq 6710b - Hi I can't adjust the brigthness
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
From the User Guide at... http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4174137&
The wireless keyboard and mouse are pre-synchronized, for your convenience, to work with your
HP TouchSmart PC. The keyboard and mouse should work immediately after you pull the battery tabs to
activate the preinstalled batteries, and then turn on the mouse (A).
You may need to manually synchronize the wireless keyboard or mouse if they are not functioning.
To synchronize them:
Make sure the keyboard and mouse are next to the HP TouchSmart PC, within 30 cm (1 foot) and
away from interference from other devices.
Keyboard: Press the Connect button on the bottom of the keyboard (B) for five seconds. The blue
activity LED on the wireless receiver illuminates when the synchronization command has been received
and turns off when synchronization is complete.
Mouse: Press the Connect button on the bottom of the mouse (C) for five seconds. The blue activity
LED on the wireless receiver illuminates when the synchronization command has been received and
If this does not work, remove and then re-insert the wireless keyboard and mouse receiver from the back of
the computer and then synchronize the keyboard and mouse again.
Fr
