My phone says not enough memory when i open music player
Are you running any other application other than the music player if you are close some of the application the phone doesnt have enough memory to play a song. If otherwise then it could be a memory issue you should show your phone to your dealer and get it fixed
i open my 5130 music player, that time see "not enough memory". please solve this problem
Try Formatting ur fone or mem card and try again
Firstly..empty your "received file" folder, music player will b start..i hv same prob..this solution helps me always..gud luck..
Ayush..
SOURCE: Music player:Not enough memory,N70
go to message menu then press options and press settings and come down to other press that and change the memory options to memory card instead of phone memory hope it works
SOURCE: When I try to open my music player it is showing
Bro it seems that your phone memory might be fully loaded.So delete the files which are located in your phone memory it'll surely help you.Good luck
SOURCE: not enough memory display when
try first deleting or erasing some of your stored messages, example sent items or inbox old items.
you can also try erasing received file or moving them to the mmc location.
also you can restore the phone factory settings, by going to settings and select restore or reset factory setting, but before doing that, be sure to BACKUP all your needed data.
SOURCE: nokia 7210 supernova in open the music player to
software problem.if u hv backup insttaled them
