Toro 13" Corded Trimmer - 51358 Logo
Posted on May 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New weed eater 13" electric trimer, want to change the spool
Apparently the weed trimmer run out of string and I need to remove the spool to restring it and cut some more weed. I can't find the manual. Is there a manual on line? Or if you give me instructions of how to restring it?
electronic & computer repair& servicre
Level 3:
  • Master 12,061 Answers
  • Posted on May 29, 2010
Master
Level 3:
Answers
12061
Questions
0
Helped
4006262
Points
36390
Usually one get a a spool of the cutting wire and it snaps into place.
http://flymolawnmower.co.cc/reviews-Toro_Electric_Trimmer_Replacement_Spool_with_065_Inch_by_10_Foot_Line_88185-B00005V7KY.html
Shows you also how to do it on package.
1helpful
2answers
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 • Worx Garden
tip
Trimmer/Weed Eater String Replacement
"How do I remove the spool and restring my trimmer?"
The spool is ******* on. There should be a Half Sphere-like object (Spool Retainer) on the bottom of the spool where the line goes. Twist counter clock-wise, or clockwise, depending on whether you have a Left-hand or Right-hand Trimmer.
If it is a duel line trimmer then:
1. Cut two separate pieces of string, about 7 ft. each.
2. Stick the end of the line in the hole on the inside of spool.
3. Wind clockwise onto spool,putting the line that is closest to the ground on first. Once you have wound this piece on, lock the last 4"-6" inches of line through one(1) of the 4 or 5 slits on spool.
4. Repeat process for second piece of line, putting it on the top side of the spool; locking the last few inches in the slot opposite the other locked in piece. (Remember, if you have a left-handed trimmer, the winding instructions will be just the opposite.)
5. Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
6. Before you push the spool all the way on, pull the strings out of the locked position.
7. Place Half-Sphere-like object back on, twisting it clock-wise to tighten.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer a little longer than 7ft.
Here is a short video that explains 3 different types of heads:
http://i.fixya.netutube.png You-Tube video "OQauZqaEBUI&feature=player_embedded" placeholder
Good Luck with your project!
Jim
Key Words: Weed Eater, Trimmer Head, String, Chainsaw, Leaf Blower, Snow Bower, Pressure Washer, & Varnisized
on Oct 04, 2010 • Garden
How to restring cordless weed trimmer
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
1helpful
2answers
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
7helpful
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
1helpful
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 • Garden
4helpful
Remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
2answers
Changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
