This freezer is about 10 years old. Last summer we had a problem with it cooling down and we unplugged it for a couple of days and quite a bit of water puddled on the floor. Does this just need a recharge because it seems to be doing the same thing..
Frigidaire has also jumped into
the market with an adaptive defrost board. The fresh food section light switch
and light bulb must work. To initiate a defrost cycle, open the door and push
the light switch in and out 5 times within 6 seconds. The compressor and fans
should shut off and the defrost heater should come on. Open the door and push
the light switch in and out 5 times within 6 seconds to remove the refrigerator
from the defrost mode and back into a cooling mode.
This product comes equipped with an
Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the
Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature
DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature
window and "F" in the refrigerator temperature window will display when the
heater is activated. To deactivate manual defrost, press and hold Freezer
temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN
(COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the
defrost cycle is complete. (approx. 8 minutes)
Your indicating a defrost problem. After you plugged unit back in did temperature drop ?
After it was unplugged the temperature dropped back down to where it should have been.
thank you
