LG 42LC2D 42 in. LCD HDTV Logo
Posted on May 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio problem; volume needs to be turned to highest level to hear a whisper. was fine last night when tv and tuner were turned off. when turned on today. the audio was non existent, turned volume to highest level to get just a whisper of volume.
Anonymous
Level 2:
  • Expert 94 Answers
  • Posted on May 28, 2010
Anonymous
Expert
Level 2:
Answers
94
Questions
0
Helped
26271
Points
161
Defective main board
New Yamaha AV Receiver and Tannoy Speakers muffled weak bass only
Maybe some wire is faulty... Try to disconnect everything and connect each speaker one by one, first trying only radio tuner and then trying to connect the TV and other devices. Using that you can isolate the fault into the specific component/wire.
3helpful
2answers
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Volume even at highest level can hardly hear..headphone volume works fine
Probably the audio amp. The headphone audio is pulled off before it gets to the audio amp for the speaker.
2answers
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
2answers
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Volume increases on its own intermittently
When the volume increased did the display show it doing so as if someone was turning the knob?  I mean did the volume go from like level 15 to 30 or did the unit's level stay constant while the audio volume increased?
Were you alone or sharing the room with a jokester who has a universal remote?
Does this problem occur when the batteries are removed from your remote?
Are you sure the 'volume up' button on the unit itself is disengaging properly after being pressed?
Audio volume level
Hi, I'm guessing your turning up the volume on the TV box to control the volume of your speakers. By doing this your only controling the audio strength coming out from the TV box.
What you should be doing is turning up the volume on your TV or amp feeding your speakers rather than the direrct TV box. The level of the speakers may have been reduced form last week (other people messing about with your equipment?) which is the reason why you have to turn it up to 30 rather than 10.
Another problem could be a loose audio connection from you direct TV box to your amp or TV. Have you tried a different source such as a DVD player, and does the sound on that seem alot quiter than before? If the volume of this is alot quiter also it could be a problem with your speakers.
Hope this helps.
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
