I replaced the lamp in my Sharp XVZ200U projector and when I plug it back in the red standby and red lamp light both come on and the projector doesn't power up when I press the on button. Therefore, I can't perform the remaining steps (input, undo, left, enter, and right) to reset the lamp timer to zero.
mainboard is not work ,it need to be repaired Have a good day! We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price. Jerry China Tel: +86 131788 67858 E-mail: [email protected] Skype: lampdeng.com YM: [email protected] http://facebook.com/lampdeng http://www.lampdeng.com
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows.
Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector)
While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector.
"LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
lamp timer do as follows. Plug the power cord into the AC socket of the
projector. Switch ON the power of the socket. (not projector) While pressing
simultaneously MENU/HELP, ENTER & DOWN (button near MENU/HELP) on the projector, press STANDBY/ON on the
projector. "LAMP 000H" is displayed, indicating that the lamp timer
is reset. If this does not correct your problem then the problem lies in
things are preliminary.
1.Attach the power cord to the projector and plug it into an electrical outlet. 2.Locate the buttons on the top of the projector and simultaneously hold
down the "Enter","Menu" and "down arrow" buttons, then press the
"Standby/On" button.
3.Continue holding all four buttons depressed until the lamp
indicator light begins flashing green.The counter is now reset. Zero
hours will now be displayed on the screen. ok
1. Plug the power cord into the AC socket of the projector. 2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector. 3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
