It will not start when you pull out the knob.
If the machine does not start.
Make sure the circuit breakers or fuses are functional in the main electrical panel.
Try to turn them OFF and ON again.
You might need to check the thermal or non thermal fuses inside your washer.
If all appears in working order, you might have a burnt motor if no noise comes from it when you pull out the knob.
Do you hear any noise from the motor or somewhere else when you pull the knob?
