Https://powersuite.cummins.com/PS5/PS5Content/SiteContent/en/Binary_Asset/pdf/Consumer/specsheets/a-1399.pdf https://power.cummins.com/sites/default/files/literature/rv/F-1123-EN.pdf
Found these do not know if they will help from my quick read they are sophisticated items and would need a proper service if faulty.
I presume the solenoid switches between battery and generator so its possible the contacts are blown and stick and will not release so that may be the fault?
Sorry hope these may help you.........
SOURCE: RV Generator Power Cutting In and Out
I'd say you probably have to have the gfi receptacle replaced. The gfi recepts can be pretty touchy sometimes. The test and reset buttons sometimes stick or do not reset due to just being old and not used very often. I am an electrician and we see this alot. I try and test mine often as I can remember to do it. If you are not qualified or experienced with this type of work please find someone who is. If you do attempt the change out, just please do it with the power to the outlet off!! Be careful around electricity! Good luck, I hope you find the right solution!
SOURCE: Portable Generator doesnt generate any AC Current
is there a manual reset circuit breaker somewhere?
SOURCE: In need of Stabilizing voltage of power generator
Solved problem upon installing a ready made stabilizer. Thanks for the opportunity to publish my inquiry. Chawah.
SOURCE: onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
