Question about Whirlpool Duet GHW9150P Front Load Washer
What does FP mean?
What FP on my whirlpool washing mean - we have lost the instruction manual - it is not draining - clothes coming out wet after a machine wash - does not finish the cycle - it stops just before spin and drain with FP showing on the electronic display.
Many thanks.
    Habit-Forming:
  • 158 Answers
Try looking online for another manual. Or call anyone who sells your machine. Me thinks the solution is simple, but you need to talk to any seller of your machine, and soon.
Posted on Mar 04, 2018
6ya staff
SOURCE:
gittos73
peter gittos
  • 247 Answers
SOURCE: Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Posted on Aug 22, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Maytag Neptune Error COde "nd"
"nd" refers to a No Drain issue . check for rstriction in pump assy, restricted drain hose loose wire at pump, bad pump
Posted on Mar 03, 2008
Anonymous
  • 1028 Answers
SOURCE: Whirlpool Ultimate Care II, model LSQ9010KQ0
lid switch lift lid and listen for click when lid shuts.. believe switch on rear left just behind lid hinge or on older models right side about half way opening (ck for boken lever or screw holes)also hinge may not be fully contacting switch ckd hinge screws just in case first if too much play in hinge will fail to contact switch..switch may be acessed by removing screws in bottom rear corners on back of console and lifting console
Posted on Jul 30, 2008
Anonymous
SOURCE: FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Posted on Dec 29, 2008
Anonymous
  • 85 Answers
SOURCE: washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
Posted on May 18, 2009
Not draining water out of clothes all the way
Check your owner's manual first.
My guess would be a clogged drain trap down by the pump. You access it by removing the front panel under the door - three screws.
There are instructions on here for cleaning it out. But check the manual first. There might be a non-invasive solution you can try first.
Jul 05, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Display is showing FP - any ideas what I need to do?
FP message (on a Whirlpool Washing Machine or derivative of it) usually means that there is a 'F'ilter issue: check your machine drain pipe and drain filter and remove any obstructions from 'stuck' objects such as socks, hanky, coins, etc ...
Sep 23, 2011 | Washing Machines
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer leaves the clothes very wet. Drain has been
What you have is a broken drive coupling. When the washer goes into spin the pump does its thing but the tub does not because the drive coupling is broken.
SOME REPAIR PICTURES WITH
REPAIR MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 28, 2009 | Whirlpool LXR6432JQ Top Load Washer
After washing clothes are still coming out wet
If its a washing machine there going to be wet arent they lol.
right if you mean that they are soaking wet after spinning it could be that the water is not draining away fully, have you checked the filter and cleaned that out, usually at the front of the machine on the bottom right. try draining that, or there could be a blockage in the waste pipe,
hope that this helps
Feb 28, 2009 | Hotpoint WMA30 Front Load Washer
Whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
380 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
